Messages
Re: Caster Wheel Alternative
John McGaw
You never did say what the floor surface is. Hardwood will have a different answer than carpet. If the former and you need to be able to slide in all directions then some really high-quality hard thick felt pads may do the trick. If the latter then there is probably no need for any sort of wheels at all -- a smooth and well-polished bottom on the tray/box will likely move with little friction as long as there is no massive weight involved.
