Messages
Re: building a tapered reamer for windsor chairs
William Duffield
The reamers that Tim Manney makes (developed by Peter Galbert, I believe) are similar to the ones in the articl John Aniano provided, with a couple of refinements.
He turns a cone on the top end and sets a small brass point in the end of the cone, to be used for aligning the reamer with the sight lines.
He also sets an adjusting screw in a tapped hole, so it engages the back of the scraper blade, to adjust and hold the exposure of the scraper.
You'll probably need to make one of these, too:
http://timmanneychairmaker.blogspot.com/2015/06/use-your-reamer-to-make-matching-tenon.html
It's a lot easier than trying to match the angle of your reamer to an existing tenon rounder.
