Messages
Re: Delta Unisaw
Re: Delta Unisaw ()
Gary Smyth
Does your blade have a bushing to fit your arbor? It may have come loose.
Is the blade arbor hole a true 5/8"? Enlarged? --
Failing observable info, have you tried to switch blades to check if problem continues?
Last resort for me. Have the arbor threads been damaged where the blade sits? Is the arbor still 5/8 with no flat area? Likely only a feeler with indicator gauge will be able to verify the arbor.
