Messages
Size Matters
The thicker the epoxy layer, the more and higher heat it will generate. Spread the mix out thin so that the reaction heat is dissipated over a wider area you'll have no issues with heat. Pour it into a hole that's a inch thick or more and you may get deformation and even fracturing in the set plastic. Put a low VP/BP solvent in to thin a thick pour and get ready for the boil-off and foam even when using slow hardeners.
