Messages
Re: Jointing long, thick (and heavy) boards?
Brian Holcombe
Do it by hand with a sharp handplane. Take consecutively longer passes toward center, then consecutively longer passes from center. The reason for doing so is to avoid making an s-shape.
Make sure your blade is flat and protruding evenly, take full width passes. Check your work with winding sticks.
I'll eventually buy a huge machine jointer, but sometimes big unweildy edge joints are easiest done by hand. Unless you have extensions.
