Hand Tools
How thick a shaving
Steve D, in CT
How thick a shaving can you take with a closed up chipbreaker?
I see two factors against that concept. One is that the chipbreaker can't be set below the sole of the plane. Also, camber is mighty useful for heavy shavings because the corners aren't in the wood causing mischief. The camber depth limits how close the chipbreaker can be set to the edge.
I don't see close chipbreakers and heavy shavings coexisting. Am I missing something?
