Hand Tools
Re: Afraid to use it
Re: Afraid to use it ()
Steve D, in CT
My 2 cents:
O1 is easy to sharpen on any stone, including natural oil stones and can be sharpened at a low angle, like 25 degrees.
I have had good experience with PM-V11 but it is more effort to sharpen and I find it very slow to hone on natural oilstones. I use Sigma Power waterstones on this steel with good results. It seems to be OK with 25 degree bevels too.
A2 if nothing else is available. I don't find any advantage that justifies the extra effort to sharpen it. I find that the bevel needs to be over 30 degrees for the edge to hold up. On a low angle bevel up plane like a DX60 the higher bevel may affect your performance with cutting end grain.
Using hollow grinds with any of those materials will greatly reduce the effort to make and maintain a sharp edge. If all you have is plain carbon steel tools, like O1, adding a more challenging steel may require new sharpening media depending on what you are doing currently.
