Hand Tools
requested format...
David Weaver
..the pieces being notched were requested to be finish ground at 70 grit or finer. I have the fineness no problem. I guess if larrin suspects and issue (Because none of the samples will be high toughness, so if they test soft on the surface, it should set off alarms), he'll do what's necessary. If the whole thing turns out to be a flop, it was worth a try.
