Hand Tools
Re: Unsolicited suggestion--Stud Mills?
H Bruce McCrory
The simple answer is "construction" grade(s) is layman-speak for wood you cull from use in furniture or trim because it is meant for studs, beams, or railroad ties. Maybe, pallets, rather than ties, if the latter are treated. Good for practice joinery.
Even the culls can be an alternate grade, because they don't meet standards for higher quality. I bought E-grade Doug fir for furniture because my needs were shorter than the 6-feet or 4-feet clear of flaws the best trim wood required. It's still "old growth" but most looks and is pretty crappy. Significantly cheaper, also.
There still may be stud mills, as opposed to more dynamic mills processing the same species types. Studs fill your "construction" term, although there are numerous other dimensions and grades that apply to the term. Softwoods are far more simplistic than hardwoods when grading for use. I would seriously pause before considering these for practice. They are barely useable for the intended purpose.
I don't consider hardwoods to be "construction" simply because softwoods (conifers) dominate the forestry industry in this area. A few small jobbers cut Alder and Madrone for niche markets. By far, those species are sold to people using wood fireplaces, or cooking meat. The only hardwoods I see are in the finish lumber and furniture bins at stores, like HD and Lowes.
Bill Tindall has about the most background for milled woods and uses on the forum.
Well, too much blowhard...
Messages In This Thread
first hand cut tails *PIC*
Re: first hand cut tails
Success will be assured
Re: Success will be assured
are you missing a piece of essential equipment
Re: are you missing a piece of essential equipment
Kirby is how I started
Advice, praise and learning curves
Re: Advice, praise and learning curves
Art, fine art, and utter messes....
I agree with what you say...however....
Re: Art, fine art, and utter messes....
Re: Peter Follansbee... *LINK*
You missed the point
Re: You missed the point
Beauty is as beauty does (in my case)
Re: Beauty is as beauty does (in my case)
my experience with the schools..
Flawed
Re: Flawed
I don't buy it...
Re: I don't buy it...
My situation was unique I think...
Is there a psychologist in the house?
The outer frame; the border. *NM*
Thanks for playing, Wiley :) *NM*
I don't think it matters...
The kids...
Re: The kids...
Re: Is there a psychologist in the house?
I'm waiting for...
Correct.
Where to start a 1000 piece jigsaw puzzle...
Where do you start a 1000-piece puzzle?
Re: Flawed
said better than I did *NM*
Re: Flawed
Re: Unsolicited suggestion--Stud Mills? Right!
I don't do a lot of dovetails...
You provided some sage advice *PIC*
Re: I don't do a lot of dovetails...
yeah...
Re: Form Follows Catches :D
Skew chisel *PIC*
Re: Skew chisel
I did my first ones in oak... *PIC*
just read bill's later post..
Re: I did my first ones in oak...
Slicks and makers
Re: Slicks and makers *PIC*
Slicks and makers
