Hand Tools
Re: Success will be assured
Success will be assured ()
eliot feldman
So nobody says,"Not too bad for the first time!" Oh well.
I now see a difference between the piano playing technique philosophy and learning to do dovetails. When you practice the technically hard passage in a real musical piece, if you mess up there's no harm at all. For the similar issue with a wood project, if you screw it up, then you've lost the project. So I see your point: To experiment more freely it's better to have nothing at risk. So practice on a a random board.
I also do tons of watercolors, and I have a teacher (in an online class) who used to beat me up about being to rigid. It was only when I let go and stopped worrying about making a masterpiece each time that I got much better. I believe it actually has to do with the left brain?right brain thing.
As for the scribe line, I did line up the tail board with the pin board and scribe one, but it seems to have disappeared. (It's a bit more visible on the other side.)
Well today, for better or worse ( worse probably) I am going to try to mark and cut the pins in some walnut. I'll post a pic when I'm done.
Messages In This Thread
first hand cut tails *PIC*
Re: first hand cut tails
Unsolicited suggestion
are you missing a piece of essential equipment
Re: are you missing a piece of essential equipment
Kirby is how I started
Advice, praise and learning curves
Re: Advice, praise and learning curves
Art, fine art, and utter messes....
I agree with what you say...however....
Re: Art, fine art, and utter messes....
Re: Peter Follansbee... *LINK*
You missed the point
Re: You missed the point
Beauty is as beauty does (in my case)
Re: Beauty is as beauty does (in my case)
my experience with the schools..
Flawed
Re: Flawed
I don't buy it...
Re: I don't buy it...
My situation was unique I think...
Is there a psychologist in the house?
The outer frame; the border. *NM*
Thanks for playing, Wiley :) *NM*
I don't think it matters...
The kids...
Re: The kids...
Re: Is there a psychologist in the house?
I'm waiting for...
Correct.
Where to start a 1000 piece jigsaw puzzle...
Where do you start a 1000-piece puzzle?
Re: Flawed
said better than I did *NM*
Re: Flawed
Re: Unsolicited suggestion
Re: Unsolicited suggestion--Stud Mills?
I don't do a lot of dovetails...
You provided some sage advice *PIC*
Re: I don't do a lot of dovetails...
yeah...
Re: Form Follows Catches :D
Skew chisel *PIC*
Re: Skew chisel
I did my first ones in oak... *PIC*
just read bill's later post..
Re: I did my first ones in oak...
Slicks and makers
Re: Slicks and makers *PIC*
Slicks and makers
