Hand Tools
Re: I follow now...
I follow now... ()
John Aniano in central NJ
David,
The 90 degree transition is abrupt but the extent of the tapered transition is spread over the 4" or so center zone. And honestly, I sort of doubt the center is properly hardened/tempered. Although saw blade will lose temper during the bending process, the action of hot forging and finishing up with a sort of cold forging might be enough to work harden the center transition zone. Just a guess.
I always saw Frank K. demonstrate his 5-minute dovetail in pine, so if a few of the center teeth don't cut really well, their job is only to turn the corner and engage the better cutting teeth past the center.
Over and out,
John
