Hand Tools
The experiment and conclusion are both confusingResponse To:
Light vs Heavy planes () Bill Tindall, E.Tn.
This discussion is not as focused as your typical submission. The stated topic is light vs heavy planes but the text scurries off in several directions ending in a conclusion- "yes .. it does add up to more in a number of ways" - not clearly supported by any preceding data. I was distracted by why you are planing a leg up hill and what the journey through frog angles had to do with the subject title.
Will you clearly state, what is the benefit you found for a heavy plane and what comparative data led to this conclusion?
Steve makes the case that a light plane excels in heavy work. If a light plane excels in heavy work would it not excel in any work, and if not why?
Messages In This Thread
- Light vs Heavy planes
- Re: Light vs Heavy planes
- not the direction I went *PIC*
- Re: reframing the issue
- The experiment and conclusion are both confusing
- At some point..
- Inertia and figured wood
- Not a positive contribution to the discussion
- finding out who to listen to...
- Turnover, newbies and FAQ
- new vs. old planes...
- I like tools from Brooklyn
- Re: I like tools from Brooklyn *NM*
- Infills in the UK
- I'm glad you commented.
- Note on a modern infill
- Re: I'm glad you commented.
- what I've found...
- Weight Comparison
- Infills in the UK
