Hand Tools
Re: A bit more info
Re: A bit more info ()
Wiley Horne
Hi David,
Any saw Bill uses will be pressed manually against the fence, so I believe his gyokucho should do just fine. Gyokuchos are plenty sharp, and the teeth are evenly set because the machine doesn’t make a mistake. Maybe that particular saw has a wide set.....? I’m overreacting a little because I gave encouragement to buy the saw.
Wiley
