Hand Tools
6 facets is better, but harder
David Weaver
I did get a chance after traveling a little bit last week to make one pencil in 6 facets. It's definitely better suited to a fingertip grip. It's also harder to make by hand, because at some point, your bearing surface will be one small facet on the pencil, the pencil is flexible, and you need to cut even facets both relative to each other and end to end (pulling the pencil across the bottom of a plane is the easiest way to cut the facets).
The other choice is to make a special plane that cuts two facets at once top and bottom, but it'll be potential trouble if there is grain misdirection between the two glued halves.
The edges left by 6 facets are much sharper, and now it's apparent why all commercial pencils have the edges broken pretty significantly.
So, after all of the screwing around, we're almost where we would've been if we just copied a commercial pencil from the start!!
Messages In This Thread
First successful (sort of) Pencil
Or, there are circular pencils
Re: Or, there are circular pencils
Re: First successful (sort of) Pencil
Re: First successful (sort of) Pencil *PIC*
Re: First successful (sort of) Pencil *LINK*
Great recommendation on the book..
Re: Great recommendation on the book..
By page 62 in petroski's text..
Pencil Two - Octagonal
Re: Pencil Two - Octagonal
times change - urushi
urushi is related to poison oak and others *LINK*
Re: urushi is related to poison oak and others
Sensitization
Re: Sensitization
Re: times change - urushi
Re: one more - shellac french polish
knife sharpening, to chisel sharpening
Re: knife sharpening, to chisel sharpening
Shellac
Water or Alcohol
6 facets on a pencil instead of 8
Re: 6 facets on a pencil instead of 8
if anyone is secretly making pencils...
My Port Orford cedar has arrived
A few more...
Re: A few more...
Re: A few more...
Re: A few more...
Re: A few more...
(I can almost guarantee)
Re: Ducking and Running *LINK*
$594!!!!
Convincing advertising
BCTW and kleptocrats
Re: BCTW and kleptocrats
The thread diverged, there...
