Hand Tools
Re: 6 facets on a pencil instead of 8
AlanWS
When I've cut hexagonal stock (as a driveshaft for a grain auger to use in moving sawdust to allow a shorter cyclone with a large bin -- unfortunately it didn't work well: planer shavings are not like grain,) the easiest way I found was to cut a rectangular cross section with a 1:1.732 ratio (sqrt 3). The short side measures the face to face distance across the final hexagon, and the long side is the point to point distance.
I cut it by tilting the tablesaw sawblade 30 degrees from square away from the fence, allowing 4 rip cuts without changing settings to establish the hexagon. Tweaking was needed only to make sure the cut met the short face halfway up.
A planing jig to hold stock at the correct angle, and a line ruled down the centers of the short faces, might make planing fairly easy. It's harder to describe than the tablesaw approach, which is why I let that leak into the hand tools section.
It's interesting that you need to plane four surfaces, whether you convert to a hexagon or an octagon.
Messages In This Thread
First successful (sort of) Pencil
Or, there are circular pencils
Re: Or, there are circular pencils
Re: First successful (sort of) Pencil
Re: First successful (sort of) Pencil *PIC*
Re: First successful (sort of) Pencil *LINK*
Great recommendation on the book..
Re: Great recommendation on the book..
By page 62 in petroski's text..
Pencil Two - Octagonal
Re: Pencil Two - Octagonal
times change - urushi
urushi is related to poison oak and others *LINK*
Re: urushi is related to poison oak and others
Sensitization
Re: Sensitization
Re: times change - urushi
Re: one more - shellac french polish
knife sharpening, to chisel sharpening
Re: knife sharpening, to chisel sharpening
Shellac
Water or Alcohol
6 facets is better, but harder
if anyone is secretly making pencils...
My Port Orford cedar has arrived
A few more...
Re: A few more...
Re: A few more...
Re: A few more...
Re: A few more...
(I can almost guarantee)
Re: Ducking and Running *LINK*
$594!!!!
Convincing advertising
BCTW and kleptocrats
Re: BCTW and kleptocrats
The thread diverged, there...
