Hand Tools
Historical yet again
I suspect that much of what we consider for final edge refinement has been derived from historical metal polishing. I don't regard edge refinement(polishing the bevel) any different technologically than surface polishing a metal part. This assumption, I'll bet, is widespread. So a woodworker sees someone polishing a piece of metal and says, I could do that to "polish" a chisel bevel. And if it worked the rest is history. That's how I got into diamonds, which I found are now widely used for metal specimen preparation and metal polishing instead of historical abrasives.
If you go back in history I suspect you will find the method you found was developed for metal surface polishing.
Messages In This Thread
Is chromium oxide honing compound still relevant
Re: Is chromium oxide honing compound still releva
Visually similar *LINK*
That is what I am going to experiment with
Appearance...
Re: Appearance...
to repeat the question....
Re: to repeat the question....
Re: to repeat the question.... *LINK*
Re: Good link, thanks. *NM*
sources
PS
Re: sources
Wiley you nailed it, I think
Diminishing returns
Re: Diminishing returns
Re: Wiley you nailed it, I think
Green and white vs. white
Historical methods
Re: Historical methods
Extrapolation of scenarios
Re: Extrapolation of scenarios
I hope brian doesn't show up...
Re: I hope brian doesn't show up...
Enlighten me
No clue about historical..
Re: Enlighten me
A minerology lesson
Re: A minerology lesson
Re: A minerology lesson *LINK*
I stand corrected
Re: Enlighten me
The emphasis on speed...
What do I have?
Something called the ‘Koch System’
Re: Something called the ‘Koch System’
The wax thing...
Re: The wax thing...
Re: Is chromium oxide vs aluminum oxide +...
Two questions remain
My opinion..
Marketing with the compounds...
G-456--not that it's practical
Or not...illegal to ship?
polishing stainless
Re: polishing stainless
