Hand Tools
Enlighten me
Historical methods ()
I did make an undocumented assumption in referring to chromium oxide as a historical abrasive for metal abrasion relative to alumina. Small particle chromium oxide would be technologically easy to manufacture. No so with submicrom alumina. In referring to chromium oxide as "historical" relative to alumina I made the assumption that people figured out how to make and use chromium oxide as a metal abrasive before submicron alumina. If this assumption is in error enlighten me of the comparative dates for when these materials became used for polishing metal.
(submicron alumina abrasive is not made by simply crushing aluminum oxide and screening)
Messages In This Thread
Is chromium oxide honing compound still relevant
Re: Is chromium oxide honing compound still releva
Visually similar *LINK*
That is what I am going to experiment with
Appearance...
Re: Appearance...
to repeat the question....
Re: to repeat the question....
Re: to repeat the question.... *LINK*
Re: Good link, thanks. *NM*
sources
PS
Re: sources
Wiley you nailed it, I think
Diminishing returns
Re: Diminishing returns
Re: Wiley you nailed it, I think
Green and white vs. white
Historical methods
Re: Historical methods
Extrapolation of scenarios
Re: Extrapolation of scenarios
I hope brian doesn't show up...
Re: I hope brian doesn't show up...
Enlighten me
No clue about historical..
Re: Enlighten me
A minerology lesson
Re: A minerology lesson
Re: A minerology lesson *LINK*
I stand corrected
Re: Enlighten me
The emphasis on speed...
What do I have?
Something called the ‘Koch System’
Historical yet again
Re: Something called the ‘Koch System’
The wax thing...
Re: The wax thing...
Re: Is chromium oxide vs aluminum oxide +...
Two questions remain
My opinion..
Marketing with the compounds...
G-456--not that it's practical
Or not...illegal to ship?
polishing stainless
Re: polishing stainless
