Hand Tools
What do I have?
The emphasis on speed... ()
Wiley Horne
Years ago, the good soul and carving instructor Nora Hall sold me some carving gouges, and along with the gouges, two German-marked buffing wheels and a block of sharpening paste. You smear the sharpening paste on the wheel.
The buffing wheels are 12mm arbor and ~4-3/4” diameter. The sharpening paste is curious: it is light green in color, and has the property that it is stiff at room temp, but liquifies as the blade/wheel surface heats up. And the liquification is not gradual—it occurs suddenly when the blade/wheel interface hits a particular temp, which ancient memory tells me is about 160F. Once this liquification happens, the cutting power of the paste is activated, and it puts a heck on an edge on carbon steel.
As I say, both the wheel and the paste are German made and marked.
Does anyone have experience with this liquifying paste? And what is it? And what is the cutting principle associated with the heat activation?
Wiley
Messages In This Thread
Is chromium oxide honing compound still relevant
Re: Is chromium oxide honing compound still releva
Visually similar *LINK*
That is what I am going to experiment with
Appearance...
Re: Appearance...
to repeat the question....
Re: to repeat the question....
Re: to repeat the question.... *LINK*
Re: Good link, thanks. *NM*
sources
PS
Re: sources
Wiley you nailed it, I think
Diminishing returns
Re: Diminishing returns
Re: Wiley you nailed it, I think
Green and white vs. white
Historical methods
Re: Historical methods
Extrapolation of scenarios
Re: Extrapolation of scenarios
I hope brian doesn't show up...
Re: I hope brian doesn't show up...
Enlighten me
No clue about historical..
Re: Enlighten me
A minerology lesson
Re: A minerology lesson
Re: A minerology lesson *LINK*
I stand corrected
Re: Enlighten me
What do I have?
Something called the ‘Koch System’
Historical yet again
Re: Something called the ‘Koch System’
The wax thing...
Re: The wax thing...
Re: Is chromium oxide vs aluminum oxide +...
Two questions remain
My opinion..
Marketing with the compounds...
G-456--not that it's practical
Or not...illegal to ship?
polishing stainless
Re: polishing stainless
