Hand Tools
Re: Diminishing returns
Diminishing returns ()
William Duffield
I go from an extra fine diamond "stone" to the 0.3 chrome on horsebutt, glued down to a piece of plywood, and pull the bevel across it about 6 times. Usually, I also lay the back of the blade flat on the strop and pull it across a couple of times. Sometimes, when sharpeninig a blade that requires a slip stone, I go directly from a translucent Arkansas stone to the chrome strop.
I never set up any experiments. I don't even have a microscope to analyze scratch patterns or count carbide chipouts. Someone had recommended chrome on this forum a few years ago, and after I figured out that Crayola has replaced the chrome in their green crayons with some sort of dye, the green powder in the above link is what I found. It just seemed to make sense to mix it with mineral oil before wiping it on the strop. I tried it for a while and was satisfied with the results, so I didn't search any further. I was never expecting anyone to ask me to publish a peer reviewed scientific paper on my results. ;^) I just wanted to get back to work with sharp tools.
Messages In This Thread
Is chromium oxide honing compound still relevant
Re: Is chromium oxide honing compound still releva
Visually similar *LINK*
That is what I am going to experiment with
Appearance...
Re: Appearance...
to repeat the question....
Re: to repeat the question....
Re: to repeat the question.... *LINK*
Re: Good link, thanks. *NM*
sources
PS
Re: sources
Wiley you nailed it, I think
Diminishing returns
Re: Wiley you nailed it, I think
Green and white vs. white
Historical methods
Re: Historical methods
Extrapolation of scenarios
Re: Extrapolation of scenarios
I hope brian doesn't show up...
Re: I hope brian doesn't show up...
Enlighten me
No clue about historical..
Re: Enlighten me
A minerology lesson
Re: A minerology lesson
Re: A minerology lesson *LINK*
I stand corrected
Re: Enlighten me
The emphasis on speed...
What do I have?
Something called the ‘Koch System’
Historical yet again
Re: Something called the ‘Koch System’
The wax thing...
Re: The wax thing...
Re: Is chromium oxide vs aluminum oxide +...
Two questions remain
My opinion..
Marketing with the compounds...
G-456--not that it's practical
Or not...illegal to ship?
polishing stainless
Re: polishing stainless
