Hand Tools
Re: to repeat the question....
Steve Voigt
Bill, perhaps you can share some links or sources…I've not found al ox in the sizes mentioned here. I can get a tin of the chromium for $10 and as William said it will probably last a lifetime. Is the same true of al ox?
Assuming it is readily available, two possible issues are grading and aggressiveness. Like I said I haven't used the chromium yet, but it's reputed to be very uniform and doesn't cut aggressively. I don't know how the al ox compares on those fronts but it does cut pretty aggressively. That's undesirable for the application I proposed, but it might be desirable for others.
Messages In This Thread
Is chromium oxide honing compound still relevant
Re: Is chromium oxide honing compound still releva
Visually similar *LINK*
That is what I am going to experiment with
Appearance...
Re: Appearance...
Re: to repeat the question.... *LINK*
Re: Good link, thanks. *NM*
sources
PS
Re: sources
Wiley you nailed it, I think
Diminishing returns
Re: Diminishing returns
Re: Wiley you nailed it, I think
Green and white vs. white
Historical methods
Re: Historical methods
Extrapolation of scenarios
Re: Extrapolation of scenarios
I hope brian doesn't show up...
Re: I hope brian doesn't show up...
Enlighten me
No clue about historical..
Re: Enlighten me
A minerology lesson
Re: A minerology lesson
Re: A minerology lesson *LINK*
I stand corrected
Re: Enlighten me
The emphasis on speed...
What do I have?
Something called the ‘Koch System’
Historical yet again
Re: Something called the ‘Koch System’
The wax thing...
Re: The wax thing...
Re: Is chromium oxide vs aluminum oxide +...
Two questions remain
My opinion..
Marketing with the compounds...
G-456--not that it's practical
Or not...illegal to ship?
polishing stainless
Re: polishing stainless
