Hand Tools
Re: Is chromium oxide honing compound still releva
David Weaver
Yes - It needs something to hold it to a strop, though (like mineral oil or something similar). I use 0.5 that hand american used to sell (no longer), and it can't be ordered without finding out the grade (the pigment is often 3 or 5 micron if it's ungraded).
Not something I use much of on tools, but the 0.5 and 0.3 will work well without creating a foil.
Strangely enough, the formax compound sold by LV and others gets a lot of grief for having aluminum oxide particles in it, but those particles are the only things making it practical to use for woodworking vs. just as an add on for a strop (that is, if someone is using it as a follow-up to a fine but not-that-fine stone to finish honing rather than just minor refinement, the al-ox is appreciated).
A typical use for something like that powder is to lap a razor 50-100 times after the finish stone and then strop after. It's a little dainty and the sharpness is transient, but it's genuine sharpness. It can be enough on a razor to lift a hair while shaving and then cut not only the hair off, but catch the skin levered up by the hair and shave it off, too (that's simply razorburn).
Messages In This Thread
Is chromium oxide honing compound still relevant
Visually similar *LINK*
That is what I am going to experiment with
Appearance...
Re: Appearance...
to repeat the question....
Re: to repeat the question....
Re: to repeat the question.... *LINK*
Re: Good link, thanks. *NM*
sources
PS
Re: sources
Wiley you nailed it, I think
Diminishing returns
Re: Diminishing returns
Re: Wiley you nailed it, I think
Green and white vs. white
Historical methods
Re: Historical methods
Extrapolation of scenarios
Re: Extrapolation of scenarios
I hope brian doesn't show up...
Re: I hope brian doesn't show up...
Enlighten me
No clue about historical..
Re: Enlighten me
A minerology lesson
Re: A minerology lesson
Re: A minerology lesson *LINK*
I stand corrected
Re: Enlighten me
The emphasis on speed...
What do I have?
Something called the ‘Koch System’
Historical yet again
Re: Something called the ‘Koch System’
The wax thing...
Re: The wax thing...
Re: Is chromium oxide vs aluminum oxide +...
Two questions remain
My opinion..
Marketing with the compounds...
G-456--not that it's practical
Or not...illegal to ship?
polishing stainless
Re: polishing stainless
