Hand Tools
Re: Is chromium oxide honing compound still releva
David Weaver
I just looked - it's a 10 stitch or so (the washers cover the center stitches) muslin wheel. If I said felt, that's because of my lack of attention to detail in most things :\ It's muslin.
Hard felt can be used with good effect, but it's really aggressive and can raise a big wire edge and round things over.
I looked under the scope off of the 5 micron wax polish and the edge is at least as fine as any shown in the test pictures with the edge durability testing. The compromise is a little bit of edge rounding due to the wheel softness, but this is an advantage on an incannel gouge because it prevents the edge failure from being a nick right at the edge (which usually means no edge failures).
I don't use it on the baldor (fear of a catch and ruining a tool slamming into some fixture on the grinder or stand), rather on a cheap harbor freight buffer.
The pair is dandy - gray scotchbrite wheels have to be one of my favorite modern tools. They leave a finish like a medium stone but cut fast, and in combination with the muslin wheel make a superb sharpening combination for incannel gouges and thin knives made out of files - things that need to be touched up often but where there's no clearance issue. The corners of the muslin wheel are soft and stay clean and a light pass through them takes off any of the remaining foil after the abrasive part of the buff is done.
The wax stick is the inexpensive al-ox stuff from mcmaster carr that's about $10 per kilogram. It's 10 lifetime's worth. Another combination that was chanced into by accident. I bought the felt wheels after seeing someone recommend them (and don't use them now), I can't remember how I got the muslin wheel, but it may have come in something cheap - as long as the last stitch is fairly close to the outside of the wheel, it should work well. I tried the compounds looking for something cheap and fast to use on MDF, but they raise a wire edge there, and the scotch brite wheel is just to clean rust off of dirty tools. I don't use any of them the way I intended, but it fits the spontaneous junk theory.
If you keep enough junk around, eventually it will organize itself into something useful (well, a tiny percentage of it will).
Messages In This Thread
Is chromium oxide honing compound still relevant
Visually similar *LINK*
That is what I am going to experiment with
Appearance...
Re: Appearance...
to repeat the question....
Re: to repeat the question....
Re: to repeat the question.... *LINK*
Re: Good link, thanks. *NM*
sources
PS
Re: sources
Wiley you nailed it, I think
Diminishing returns
Re: Diminishing returns
Re: Wiley you nailed it, I think
Green and white vs. white
Historical methods
Re: Historical methods
Extrapolation of scenarios
Re: Extrapolation of scenarios
I hope brian doesn't show up...
Re: I hope brian doesn't show up...
Enlighten me
No clue about historical..
Re: Enlighten me
A minerology lesson
Re: A minerology lesson
Re: A minerology lesson *LINK*
I stand corrected
Re: Enlighten me
The emphasis on speed...
What do I have?
Something called the ‘Koch System’
Historical yet again
Re: Something called the ‘Koch System’
The wax thing...
Re: The wax thing...
Re: Is chromium oxide vs aluminum oxide +...
Two questions remain
My opinion..
Marketing with the compounds...
G-456--not that it's practical
Or not...illegal to ship?
polishing stainless
Re: polishing stainless
