Hand Tools
clever setting procedure; blurring? *PIC*
Re: question ()
I am anxious to employ the cap iron setting procedure you described. I'll use my dovetail chopping finesse.
Sandpaper tends to blur the edges of stringing and inlay—has to be cut with a tool to get a sharp result.
The holly string was scraped level and then the whole affair sanded to 180 followed by garnet shellac sanded in between coats (don't recall how many, probably 3). I scrape(level) as I install and move along piece by piece at a rate, limited by patience. If by blurring you mean fuzziness at the edges, I don't see it.
Messages In This Thread
Heat balance at plane blade tip
Re: Heat balance at plane blade tip
K&K SEM pictures
Re: K&K SEM pictures—here they are *LINK*
Re: K&K SEM pictures *LINK*
The data shown above
Re: The data shown above
Re: Agree on three points
Question about setting blade exposure
Re: Question about setting blade exposure
Is planing the way to level this surface
Toothing planes
Gosh...
Re: Gosh...
Re: Gosh...
Re: Is planing the way to level this surface
Re: Question about setting blade exposure *PIC*
summary?
Re: summary?
A small experiment
Re: A small experiment
question
Re: question
Re: clever setting procedure; blurring?
Holly inlay properties
Divergence from the classic
Re: totes etc.
Re: Handle shaping method and tools... *LINK*
I used to get fired up...
The whole translation/review—for the obsessed *LINK*
Re: The whole translation/review—for the obsesse
Where is this going?
The purpose of the original test...
Re: The purpose of the original test...
What's allowed on forums?
you underestimate the interest
Re: you underestimate the interest
bored to tears ?
Re: bored to tears ?
There is one thing remaining..
My suspicion...
Re: My suspicion...
Re: My suspicion...
Another table from SB
Yes - the confusion without XHP
Odd thing about CTS-XHP wear resistance
All metal wear not equal
Re: This isn't Instagram
Re: not quite, but find what you like...
David - keep at it
Re: David - keep at it
I don't understand social media
