Hand Tools
Re: bored to tears ?
bored to tears ? ()
Warren in Lancaster, PA
It will take one graph and 2 minutes explanation to summarize David's blade metal results. Either you are planning on more verbiage than necessary or your group has less attention span than the average teen ager.
And, why is it that knife enthusiasts are passionately interested in the metals their blade is made from and supposedly planing enthusiasts are not?
The noun "metal" is usually reserved for elements. We use the term alloy or steel (which is an alloy) for plane iron material. For centuries.
You can summerize David's results if you want, but the subject is much more complicated, once you start asking questions. Like why did David use diamonds to sharpen the irons? Was it only to accommodate the more goofball materials he tested? Or if he used a sharpening method that took four times as long as his normal routine, where is the savings? Is it true that some of these alloys "take a crappy edge and hold it forever"?
I cannot imagine someone familiar with this stuff suggesting it could be summerized in two minutes.
Messages In This Thread
Heat balance at plane blade tip
Re: Heat balance at plane blade tip
K&K SEM pictures
Re: K&K SEM pictures—here they are *LINK*
Re: K&K SEM pictures *LINK*
The data shown above
Re: The data shown above
Re: Agree on three points
Question about setting blade exposure
Re: Question about setting blade exposure
Is planing the way to level this surface
Toothing planes
Gosh...
Re: Gosh...
Re: Gosh...
Re: Is planing the way to level this surface
Re: Question about setting blade exposure *PIC*
summary?
Re: summary?
A small experiment
Re: A small experiment
question
Re: question
clever setting procedure; blurring? *PIC*
Re: clever setting procedure; blurring?
Holly inlay properties
Divergence from the classic
Re: totes etc.
Re: Handle shaping method and tools... *LINK*
I used to get fired up...
The whole translation/review—for the obsessed *LINK*
Re: The whole translation/review—for the obsesse
Where is this going?
The purpose of the original test...
Re: The purpose of the original test...
What's allowed on forums?
you underestimate the interest
Re: you underestimate the interest
bored to tears ?
There is one thing remaining..
My suspicion...
Re: My suspicion...
Re: My suspicion...
Another table from SB
Yes - the confusion without XHP
Odd thing about CTS-XHP wear resistance
All metal wear not equal
Re: This isn't Instagram
Re: not quite, but find what you like...
David - keep at it
Re: David - keep at it
I don't understand social media
