Hand Tools
Re: A small experiment
A small experiment ()
david weaver
Love the shavings with the pattern in them!
Your numbers come up to what I measured with the microscope against a piece of wire known to be 7 thousandths in diameter.
Early discussions centered around trying to get sets based on shims, but it's not necessary. Setting the cap right on the edge and then "just until you see a glint of light)" will easily yield something like 4 thousandths and then "a little bit more space than that" will double it. The two are discernibly different and one with less experience (like me) will end up settling around there with a smoother because it's safe.
I mentioned the closed mouth (And warren the thin shaving), not because tearout might be an issue, but because breakout of fibers on the ends of pieces obviously could be. The one thing where a cap iron is not an asset is planing across grain and rolling fibers off. Ends of boards with bad grain also present this, where the resistance of pushing a chip, even a little bit, can plane the very edge off of such a board.
It's sort of a false dilemma in that case, because you wouldn't want to work dovetails into such a board, either. They'd have no strength and cutting / paring sockets in half blinds in wood like that is miserable.
Messages In This Thread
Heat balance at plane blade tip
Re: Heat balance at plane blade tip
K&K SEM pictures
Re: K&K SEM pictures—here they are *LINK*
Re: K&K SEM pictures *LINK*
The data shown above
Re: The data shown above
Re: Agree on three points
Question about setting blade exposure
Re: Question about setting blade exposure
Is planing the way to level this surface
Toothing planes
Gosh...
Re: Gosh...
Re: Gosh...
Re: Is planing the way to level this surface
Re: Question about setting blade exposure *PIC*
summary?
Re: summary?
A small experiment
question
Re: question
clever setting procedure; blurring? *PIC*
Re: clever setting procedure; blurring?
Holly inlay properties
Divergence from the classic
Re: totes etc.
Re: Handle shaping method and tools... *LINK*
I used to get fired up...
The whole translation/review—for the obsessed *LINK*
Re: The whole translation/review—for the obsesse
Where is this going?
The purpose of the original test...
Re: The purpose of the original test...
What's allowed on forums?
you underestimate the interest
Re: you underestimate the interest
bored to tears ?
Re: bored to tears ?
There is one thing remaining..
My suspicion...
Re: My suspicion...
Re: My suspicion...
Another table from SB
Yes - the confusion without XHP
Odd thing about CTS-XHP wear resistance
All metal wear not equal
Re: This isn't Instagram
Re: not quite, but find what you like...
David - keep at it
Re: David - keep at it
I don't understand social media
