Hand Tools
Re: Question about setting blade exposure
Warren in Lancaster, PA
I have used a plane for this type of work for almost forty years.
In many woodworking operations the skill is to quickly get close to the final form and then more delicately finish up. In carving, for example, being able to rough out quickly is where you make your money. In ripping you want to saw very near the line so there is not much planing work, and in bringing a board to thickness you want to get very close to the line with the jack plane before using a trying plane.
In this case I would take a different approach. I would set the iron very fine and take my time about bringing things level. You want to sharpen often because the edge is subject to all kinds of discontinuities: edges of inlay, glue lines, grain changes etc. which are rough on the edge. The sharper the iron, the cleaner the cut.
Messages In This Thread
Heat balance at plane blade tip
Re: Heat balance at plane blade tip
K&K SEM pictures
Re: K&K SEM pictures—here they are *LINK*
Re: K&K SEM pictures *LINK*
The data shown above
Re: The data shown above
Re: Agree on three points
Is planing the way to level this surface
Toothing planes
Gosh...
Re: Gosh...
Re: Gosh...
Re: Is planing the way to level this surface
Re: Question about setting blade exposure *PIC*
summary?
Re: summary?
A small experiment
Re: A small experiment
question
Re: question
clever setting procedure; blurring? *PIC*
Re: clever setting procedure; blurring?
Holly inlay properties
Divergence from the classic
Re: totes etc.
Re: Handle shaping method and tools... *LINK*
I used to get fired up...
The whole translation/review—for the obsessed *LINK*
Re: The whole translation/review—for the obsesse
Where is this going?
The purpose of the original test...
Re: The purpose of the original test...
What's allowed on forums?
you underestimate the interest
Re: you underestimate the interest
bored to tears ?
Re: bored to tears ?
There is one thing remaining..
My suspicion...
Re: My suspicion...
Re: My suspicion...
Another table from SB
Yes - the confusion without XHP
Odd thing about CTS-XHP wear resistance
All metal wear not equal
Re: This isn't Instagram
Re: not quite, but find what you like...
David - keep at it
Re: David - keep at it
I don't understand social media
