Hand Tools
Re: Question about setting blade exposure
David Weaver
I think if the shaving is being worked, you're getting most of the effect. If it's coming out of a plane, not shortened so much (that's a pretty stout set), but just straightening some.
When you plane something like maple (too much recent experience), it'll be 95% super bright and then with a couple of spots of small tearout. You can plane it safely with a set that straightens the chip a little bit and then back the setting off and take your finish passes without changing anything on the plane and be in good shape.
Usually, if you have to resort to putting the cap in office paper distance, you're going to end up with a surface that's a little fuzzy to the touch because some of the fibers are facing right back into the blade. If they lean enough either way otherwise and are packed closely together, the surface is pretty good.
Any work to the shaving (other than allowing the shaving to curl up into a tight curl - no effect), kind of lets you know that nothing catastrophic that would cause you to blow past a mark will happen.
Messages In This Thread
Heat balance at plane blade tip
Re: Heat balance at plane blade tip
K&K SEM pictures
Re: K&K SEM pictures—here they are *LINK*
Re: K&K SEM pictures *LINK*
The data shown above
Re: The data shown above
Re: Agree on three points
Is planing the way to level this surface
Toothing planes
Gosh...
Re: Gosh...
Re: Gosh...
Re: Is planing the way to level this surface
Re: Question about setting blade exposure *PIC*
summary?
Re: summary?
A small experiment
Re: A small experiment
question
Re: question
clever setting procedure; blurring? *PIC*
Re: clever setting procedure; blurring?
Holly inlay properties
Divergence from the classic
Re: totes etc.
Re: Handle shaping method and tools... *LINK*
I used to get fired up...
The whole translation/review—for the obsessed *LINK*
Re: The whole translation/review—for the obsesse
Where is this going?
The purpose of the original test...
Re: The purpose of the original test...
What's allowed on forums?
you underestimate the interest
Re: you underestimate the interest
bored to tears ?
Re: bored to tears ?
There is one thing remaining..
My suspicion...
Re: My suspicion...
Re: My suspicion...
Another table from SB
Yes - the confusion without XHP
Odd thing about CTS-XHP wear resistance
All metal wear not equal
Re: This isn't Instagram
Re: not quite, but find what you like...
David - keep at it
Re: David - keep at it
I don't understand social media
