Hand Tools
Re: read my article on wheels
read my article on wheels ()
Bill, if you are content with your oink wheel, just carry on. However, a CBN wheel is in a different league. Heat and speed aside, an advantage of the CBN wheel is that it does not require any maintenance. The wheel does not change shape, does not need resurfacing, which means that set up does not alter. Would you return to your old steel after 3V?
