Hand Tools
Re: Klaus's Trick
Re: Klaus's Trick ()
Joe Rogers, Northern Virginia
Roy Underhill had/has a frame saw fitted with the turning blade. IIRC he modified the blade himself. He explained the blade was fragile and nearly broken at the twist where the heat was applied. He did demo the cut at the Woodcraft store where he was appearing. It required some finesse to get through the transition.
Joe
BTW username location is out of date, retired and further north in eastern WV
