Hand Tools
Re: Windsor mortice and tenon
david weaver
The principle you describe holds true for planes. There is a wider range of hold for less taper. If the wedge has more taper, it tends to just pop out. Really hard wood and too much taper is a bad combination.
I've never measured plane wedge taper, I can just recall wedges that visually have more vs. those that have less. it's probably in the same ballpark as the chair taper values, though - probably between those.
