Hand Tools
Re: Narex parers
Narex parers ()
david weaver
You could make the Blue Spruce chisels (they are just flat stock stabbed in a handle - albeit a superbly turned handle), and I hope I don't make any enemies saying this, but at $40-$50 each for vintage paring chisels, nobody should consider them at what they cost at least until the supply of vintage chisels has dried up. From a use perspective, it makes no sense.
The entire balance of usability with paring chisels (once proper slimness is achieved) is dependent on a fine edge and the balance of sharpening vs. use time.
(the attractive octagonal bolster on the older chisels is just a bonus - a nice thing to have around to copy in case you ever get the urge to grind or saw/file a chisel out of flat stock).
I'm going to assume that Narex makes the parers thick because they are more stable for machining. Even sheffield makers backed off a little and made chisels a bit thicker (not nearly as heavy as Narex, though) with fairly fat lands, and eventually, the bolster became round. I can't remember the bolster shape on mine, but the words "chrome vanadium" on the back of the chisels still sticks out to me because you don't often see such a thing on a chisel with a boxwood handle and a bolster. I'm not sure I'd suspect much regarding the steel if I hadn't seen that - it's really pretty mellow.
Messages In This Thread
premium chisel vs narex
Re: premium chisel vs narex
very detailed info
Re: Lee Valley...
Narex heat-treatment process
Re: Narex heat-treatment process
Narex heat treatment process
A question of clarification......
Re: A question of clarification......
Questions on sharpening a Koymaichi.....
Re: Questions on sharpening a Koymaichi.....
Tormek blade holding
SE-77
i agree
What we often forget...
handles
True thing...
Re: handles
Re: Unless....
Not intentionally (or consistently) hollowed
Re: Not intentionally (or consistently) hollowed
Speaking of the shoes of others
Re: Speaking of the shoes of others
"Premium" or "Dovetail" chisels?
Re: "Premium" or "Dovetail" chisels?
Re: after looking....
Narex parers
Re: Narex parers
