Hand Tools
Plastic laminating sheet
Re: Stearate coating ()
Patrick Chase
LV actually sells sheets for the purpose, so I can't claim to have invented this: http://www.leevalley.com/us/Wood/page.aspx?p=33017&cat=1,43072,67174&ap=1. For grits finer than #150 these much cheaper sheets work very well: https://www.amazon.com/C-Line-Heavyweight-Adheer-Laminating-65003/dp/B001P4VKG8/ref=sr_1_1?ie=UTF8&qid=1512235147&sr=8-1&keywords=super+heavyweight+laminating+sheet
There is one key thing to keep in mind about lapping with loose grains, that may seem counterintuitive: Softer materials preferentially lap harder ones. The loose grains tend to "stick" in the softer material, and that causes them to abrade the harder material. That's why cast iron laps work so well to abrade tool steel with diamond compounds.
Glass and granite surface plates are both very hard, so they tend to get damaged when you use them directly to flatten sharpening stones. The laminating sheet provides a flat intermediate surface to "capture" the abrasive grains. It both speeds the process up (a lot) and protects your reference surface.
Messages In This Thread
flattening Waterstones- shapton pro
Re: flattening Waterstones- shapton pro
Flattening
Revise atoma price...
Re: Revise dia-sharp price...
Diamond plates
Re: Diamond plates
Diamond plates......
Re: diasharp vs. diaflat
Re: I think...
Re: I think...
Yes, this
lapping film?
Re: lapping film?
Re: lapping film?
you are not kidding!
Re: lapping film?
A different perspective *LINK*
Re: A different perspective
Not universal preference
to date
Re: to date
Re: to date
Re: to date
Re: to date
:) *NM*
Re: to date
My Opinion...
Re: My Opinion...
My thoughts
Re: My thoughts
Re: My thoughts
The flat wheel surface - or not..
Re: The flat wheel surface - or not..
CBN and grit
How Are You Cleaning The CBN Wheel . . .
Re: How Are You Cleaning The CBN Wheel . . .
Why grind unhardened steel on CBN?
Re: Why grind unhardened steel on CBN?
Quick and dirty summary:
Re: Quick and dirty summary:
Atoma - $64
Re: Atoma - $64
Sandpaper Flattening & Shaptons
Re: Sandpaper Flattening & Shaptons
Stearate coating
which side to use?
Re: which side to use?
a little bit the Indian and a little bit arrow
Re: a little bit the Indian and a little bit arrow
What a great thread this has been.....
Re: What a great thread this has been.....
Traditional Method
Re: Traditional Method
Re: Traditional Method *LINK* *PIC*
My apologies for being a bit too harsh..
Re: Washita vs soft Arkansas stones...
well then....
Another possibility presents itself......
CBN plates
Re: Not making sense..
Diamond wear
Re: Diamond wear
Re: Diamond wear
Re: Diamond wear
