Hand Tools
Re: How Are You Cleaning The CBN Wheel . . .
Patrick Chase
Are you using laminated (Japanese) plane irons and chisels?
Homogeneous Western tools that are hardened all the way through are typically Rc59 and above, and that's enough not to clog a CBN wheel. I don't worry about it or clean the wheel at all.
Mild steels and iron can indeed load the wheel. That's only happened to me once that I remember, when I used my CBN wheel to shape some mild 1018. I ground a hardened scraper (~Rc52) a bit to remove it and the wheel didn't seem any worse for wear, though I've avoided unhardened metals since.
I don't hollow-grind laminated tools in any case. They don't really need it because they sharpen so easily to begin with, and I'm concerned that hollow-grinding slightly compromises the integrity of the weld. I don't know if it's enough to matter, but I don't take chances.
Messages In This Thread
flattening Waterstones- shapton pro
Re: flattening Waterstones- shapton pro
Flattening
Revise atoma price...
Re: Revise dia-sharp price...
Diamond plates
Re: Diamond plates
Diamond plates......
Re: diasharp vs. diaflat
Re: I think...
Re: I think...
Yes, this
lapping film?
Re: lapping film?
Re: lapping film?
you are not kidding!
Re: lapping film?
A different perspective *LINK*
Re: A different perspective
Not universal preference
to date
Re: to date
Re: to date
Re: to date
Re: to date
:) *NM*
Re: to date
My Opinion...
Re: My Opinion...
My thoughts
Re: My thoughts
Re: My thoughts
The flat wheel surface - or not..
Re: The flat wheel surface - or not..
CBN and grit
Why grind unhardened steel on CBN?
Re: Why grind unhardened steel on CBN?
Quick and dirty summary:
Re: Quick and dirty summary:
Atoma - $64
Re: Atoma - $64
Sandpaper Flattening & Shaptons
Re: Sandpaper Flattening & Shaptons
Stearate coating
Re: Stearate coating
Plastic laminating sheet
which side to use?
Re: which side to use?
a little bit the Indian and a little bit arrow
Re: a little bit the Indian and a little bit arrow
What a great thread this has been.....
Re: What a great thread this has been.....
Traditional Method
Re: Traditional Method
Re: Traditional Method *LINK* *PIC*
My apologies for being a bit too harsh..
Re: Washita vs soft Arkansas stones...
well then....
Another possibility presents itself......
CBN plates
Re: Not making sense..
Diamond wear
Re: Diamond wear
Re: Diamond wear
Re: Diamond wear
