Hand Tools
Re: Stearate coating
Re: Stearate coating ()
Patrick Chase
I should be clear that I use diamond plates (mostly Atoma) for the vast majority of stone-flattening chores. As you say they get the job done quickly and at least as cleanly as any other option.
Unfortunately I own some stones that can't be allowed to interact with a diamond plate. For example, I stripped almost all of the diamonds off of a 10" x 4" DiaFlat (a $200 plate...) by using it to true up a Sigma Select II #240. I expect that I'd see similar results with coarse SiC-based stones like a Crystolon or my Sigma #120.
I use a well-worm Atoma #140 plate to flatten stones down to #320 or so, but below that I switch to loose SiC grit. It's almost as fast as a diamond plate once you have the hang of it (and figure out some tricks like using sacrificial plastic laminating sheets to "hold" the grit), though it makes a god-awful mess.
Messages In This Thread
flattening Waterstones- shapton pro
Re: flattening Waterstones- shapton pro
Flattening
Revise atoma price...
Re: Revise dia-sharp price...
Diamond plates
Re: Diamond plates
Diamond plates......
Re: diasharp vs. diaflat
Re: I think...
Re: I think...
Yes, this
lapping film?
Re: lapping film?
Re: lapping film?
you are not kidding!
Re: lapping film?
A different perspective *LINK*
Re: A different perspective
Not universal preference
to date
Re: to date
Re: to date
Re: to date
Re: to date
:) *NM*
Re: to date
My Opinion...
Re: My Opinion...
My thoughts
Re: My thoughts
Re: My thoughts
The flat wheel surface - or not..
Re: The flat wheel surface - or not..
CBN and grit
How Are You Cleaning The CBN Wheel . . .
Re: How Are You Cleaning The CBN Wheel . . .
Why grind unhardened steel on CBN?
Re: Why grind unhardened steel on CBN?
Quick and dirty summary:
Re: Quick and dirty summary:
Atoma - $64
Re: Atoma - $64
Sandpaper Flattening & Shaptons
Re: Sandpaper Flattening & Shaptons
Stearate coating
Plastic laminating sheet
which side to use?
Re: which side to use?
a little bit the Indian and a little bit arrow
Re: a little bit the Indian and a little bit arrow
What a great thread this has been.....
Re: What a great thread this has been.....
Traditional Method
Re: Traditional Method
Re: Traditional Method *LINK* *PIC*
My apologies for being a bit too harsh..
Re: Washita vs soft Arkansas stones...
well then....
Another possibility presents itself......
CBN plates
Re: Not making sense..
Diamond wear
Re: Diamond wear
Re: Diamond wear
Re: Diamond wear
