Hand Tools
Re: The flat wheel surface - or not..
david weaver
I no longer have a tormek, but I had one, so I recall that holder system (except I didn't build a separate base). It should be doable to just move the blade back and forth over the part of the wheel that's doing the cutting (which is essentially what I do freehand). If someone was anal retentive, they could orient your rest setup so that both outside edges of the wheel were doing work and worry about using the middle of the outsides ever seem to stop cutting (they probably won't).
I had enough of all of the tormek bits pretty early, but I have decent (but relatively small, which I prefer) two-piece cast rests on my grinder. I think the whole setup is a detriment in this case, and a grinder with decent rests would be better and more productive. But it still shouldn't be an issue with the wheel, as your wooden bases could be reoriented however you'd like.
Messages In This Thread
flattening Waterstones- shapton pro
Re: flattening Waterstones- shapton pro
Flattening
Revise atoma price...
Re: Revise dia-sharp price...
Diamond plates
Re: Diamond plates
Diamond plates......
Re: diasharp vs. diaflat
Re: I think...
Re: I think...
Yes, this
lapping film?
Re: lapping film?
Re: lapping film?
you are not kidding!
Re: lapping film?
A different perspective *LINK*
Re: A different perspective
Not universal preference
to date
Re: to date
Re: to date
Re: to date
Re: to date
:) *NM*
Re: to date
My Opinion...
Re: My Opinion...
My thoughts
Re: My thoughts
Re: My thoughts
CBN and grit
How Are You Cleaning The CBN Wheel . . .
Re: How Are You Cleaning The CBN Wheel . . .
Why grind unhardened steel on CBN?
Re: Why grind unhardened steel on CBN?
Quick and dirty summary:
Re: Quick and dirty summary:
Atoma - $64
Re: Atoma - $64
Sandpaper Flattening & Shaptons
Re: Sandpaper Flattening & Shaptons
Stearate coating
Re: Stearate coating
Plastic laminating sheet
which side to use?
Re: which side to use?
a little bit the Indian and a little bit arrow
Re: a little bit the Indian and a little bit arrow
What a great thread this has been.....
Re: What a great thread this has been.....
Traditional Method
Re: Traditional Method
Re: Traditional Method *LINK* *PIC*
My apologies for being a bit too harsh..
Re: Washita vs soft Arkansas stones...
well then....
Another possibility presents itself......
CBN plates
Re: Not making sense..
Diamond wear
Re: Diamond wear
Re: Diamond wear
Re: Diamond wear
