Hand Tools
Re: The flat wheel surface - or not..
Hi David
It is relevant to understand the context of my concern with a slight convex on the radius wheel. I wrote this up on my website in CBN article. In my case it comes down to the 180 grit wheel being used with the Tormek blade holder (the BGM -100). This runs past the wheel on rails, and needs the face to be aligned.
"The problem is that the Tormek has a friable wheel and, using the BGM-100 set up, the wheel can be trued to it. However the CBN wheels are not friable. Therefore there can be no adjustment. If the wheels are not square, then you are in trouble! On the other hand, if you are not using the BGM -100, then you have wider options".
My 80 grit wheel has a simple rest where blades are ground freehand. Nevertheless, a slight convex here means that only the centre of the face cannot be used by moving the blade across the wheel since there is a dip at that point.
Messages In This Thread
flattening Waterstones- shapton pro
Re: flattening Waterstones- shapton pro
Flattening
Revise atoma price...
Re: Revise dia-sharp price...
Diamond plates
Re: Diamond plates
Diamond plates......
Re: diasharp vs. diaflat
Re: I think...
Re: I think...
Yes, this
lapping film?
Re: lapping film?
Re: lapping film?
you are not kidding!
Re: lapping film?
A different perspective *LINK*
Re: A different perspective
Not universal preference
to date
Re: to date
Re: to date
Re: to date
Re: to date
:) *NM*
Re: to date
My Opinion...
Re: My Opinion...
My thoughts
Re: My thoughts
Re: My thoughts
CBN and grit
How Are You Cleaning The CBN Wheel . . .
Re: How Are You Cleaning The CBN Wheel . . .
Why grind unhardened steel on CBN?
Re: Why grind unhardened steel on CBN?
Quick and dirty summary:
Re: Quick and dirty summary:
Atoma - $64
Re: Atoma - $64
Sandpaper Flattening & Shaptons
Re: Sandpaper Flattening & Shaptons
Stearate coating
Re: Stearate coating
Plastic laminating sheet
which side to use?
Re: which side to use?
a little bit the Indian and a little bit arrow
Re: a little bit the Indian and a little bit arrow
What a great thread this has been.....
Re: What a great thread this has been.....
Traditional Method
Re: Traditional Method
Re: Traditional Method *LINK* *PIC*
My apologies for being a bit too harsh..
Re: Washita vs soft Arkansas stones...
well then....
Another possibility presents itself......
CBN plates
Re: Not making sense..
Diamond wear
Re: Diamond wear
Re: Diamond wear
Re: Diamond wear
