Hand Tools
Re: Diamond plates
Diamond plates ()
david weaver
I don't think the lapping problems are confined to the ezelap. DMT hones have a reputation for "breaking in" quickly, but one of the bloggers (science or sharp or something) actually took pictures of the plate surface years ago and the "breaking in" is the release of absurdly large diamonds. What's left after the break in is still some mono diamonds that should never have been on the plate in the first place.
My ezelap feels very fine to the touch with metal (probably because metal doesn't provide any resistance to the diamonds cutting). You could feel the pull on the watch face, and by the time you figure out what it is, too late, the damage is done.
I don't have a newer DMT or I'd take the edge picture of various tools on each brand of hone.
As far as the flattening issue, make sure you're using the entire surface of the atoma. I've used mine for both sharpening and flattening (more stones in the long run than tools, now) and they have no issues with flatness. They are the only two diamond hones that I have (my duosharp is beat and without diamonds in the middle) that can be used interchangeably.
Unless you're using hap40 or something, though, I can't think of any good reason to sharpen with diamond hones. A grinder is better for grinding, and stones are better for honing. And if you're using hap40 on a regular basis, I hope you're cutting through staples - otherwise, it's sort of a nuisance that still drops its initial edge pretty quickly and then holds whatever is left for a long time.
Messages In This Thread
flattening Waterstones- shapton pro
Re: flattening Waterstones- shapton pro
Flattening
Revise atoma price...
Re: Revise dia-sharp price...
Diamond plates
Re: Diamond plates
Diamond plates......
Re: diasharp vs. diaflat
Re: I think...
Re: I think...
Yes, this
lapping film?
Re: lapping film?
Re: lapping film?
you are not kidding!
Re: lapping film?
A different perspective *LINK*
Re: A different perspective
Not universal preference
to date
Re: to date
Re: to date
Re: to date
Re: to date
:) *NM*
Re: to date
My Opinion...
Re: My Opinion...
My thoughts
Re: My thoughts
Re: My thoughts
The flat wheel surface - or not..
Re: The flat wheel surface - or not..
CBN and grit
How Are You Cleaning The CBN Wheel . . .
Re: How Are You Cleaning The CBN Wheel . . .
Why grind unhardened steel on CBN?
Re: Why grind unhardened steel on CBN?
Quick and dirty summary:
Re: Quick and dirty summary:
Atoma - $64
Re: Atoma - $64
Sandpaper Flattening & Shaptons
Re: Sandpaper Flattening & Shaptons
Stearate coating
Re: Stearate coating
Plastic laminating sheet
which side to use?
Re: which side to use?
a little bit the Indian and a little bit arrow
Re: a little bit the Indian and a little bit arrow
What a great thread this has been.....
Re: What a great thread this has been.....
Traditional Method
Re: Traditional Method
Re: Traditional Method *LINK* *PIC*
My apologies for being a bit too harsh..
Re: Washita vs soft Arkansas stones...
well then....
Another possibility presents itself......
CBN plates
Re: Not making sense..
Diamond wear
Re: Diamond wear
Re: Diamond wear
Re: Diamond wear
