Hand Tools
Re: premium chisel vs narex
premium chisel vs narex ()
Patrick Chase
Narex uses a single step hardening/tempering process (austempering in a molten salt bath, with interrupted quench) that produces a relatively small amount of warp. They take advantage of that to reduce their costs, by doing 100% of their machining before heat treatment.
In contrast the premium makers all post-machine after HT. This has two benefits:
1. Better geometry and therefore less setup/tuning for the end user. Narex' HT process produces admirably low distortion, but it's not as good as can be achieved with careful post-machining. That's probably why your premium chisel took so much less effort to set up.
2. HT can leave some (relatively) soft/decarburized steel at the surface, and post-machining gets rid of that. That may explain why the Narex chisels require some break-in. I've seen the same BTW.
Messages In This Thread
very detailed info
Re: Lee Valley...
Narex heat-treatment process
Re: Narex heat-treatment process
Narex heat treatment process
A question of clarification......
Re: A question of clarification......
Questions on sharpening a Koymaichi.....
Re: Questions on sharpening a Koymaichi.....
Tormek blade holding
SE-77
i agree
What we often forget...
handles
True thing...
Re: handles
Re: Unless....
Not intentionally (or consistently) hollowed
Re: Not intentionally (or consistently) hollowed
Speaking of the shoes of others
Re: Speaking of the shoes of others
"Premium" or "Dovetail" chisels?
Re: "Premium" or "Dovetail" chisels?
Re: after looking....
Narex parers
Re: Narex parers
