Hand Tools
Final smoothing isn't the problem
Re: First one I saw... ()
Patrick Chase
Who said anything about "final smoothing"?
Smoothing has never been the limiting step when it comes to tearout. As you say, there are several viable tearout mitigations for smoothing planes: High angle, ultra-thin shavings, ultra-sharp and frequently sharpened irons, cap irons, etc. If smoothing is all you do by hand then you can achieve good results in reasonable (though not optimal) time without a double iron.
The biggest payoff from the double iron is when you need to remove volume rather than just clean up the surface, as in jointing and roughing. In that case most of the other mitigations become nonviable for one reason or another: Thin shavings take forever, maintaining an ultra-sharp edge is impractical, high angles are too much work, etc. Double irons are petty much the only game in town for that sort of work. Note that deep cuts cause deep tearout, so if you get into trouble in the jointing phase then your smoothing will take forever as well.
This is why David keeps going on and on about "people who rough their own wood".
Messages In This Thread
LV replacement cap irons......
Re: LV replacement cap irons......
Re: I should add..
Crude cap irons
Re: Stamping..
Re: It's worth a chuckle
Heavier Stanley cap-iron
Re: Heavier Stanley cap-iron
First one I saw...
That would've been my guess
Re: Final smoothing isn't the problem
very interesting article *LINK*
Re: very interesting article
Re: Breaker, breaker, on mine, clear the pine
re: bevel-up
Re: re: bevel-up
Re: First one I saw... *PIC*
Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper *PIC*
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Quality is relative
Not really...
Re: growing pains..
Re: growing pains..
Re: growing pains..
Re: Latest Development
stay set
Re: stay set
The internet hasn't helped in some things..
Re: And it hasn't helped in others...
Re: The internet hasn't helped in some things..
Re: LV replacement cap irons...... *LINK*
