Hand Tools
Re: And it hasn't helped in others...
david weaver
..if you go to most forums, you'll find glowing reviews about the stayset, but woven into them are all kinds of tips about how to make it work better. The conclusion from the fans seems to lean toward "but they're still way better than stanley - they're thicker plus it's two pieces instead of one". Fellows like you and me tend to think "oh well, maybe mine just wasn't quite right" and the fans win out.
I guess the concept sounds great when someone finds putting a cap iron back on a plane to be a precarious time sucking event, but if it was that big of an issue, I think it would've been done that way on stanley planes, too.
My lone remaining stayset has been far more trouble than its worth. It looks like they fetch well on ebay, though - so that's good. Good idea in concept (still think so even though actual use doesn't bear it out that consistently) - even with the cap set close, you could hone a few times before you had to reset it. But taking the plane apart from time to time to remove shavings that got between the iron and cap iron - not much of a time saver. Twice in a row in a few strokes, and the plane is in danger of being tested for flight characteristics.
Messages In This Thread
LV replacement cap irons......
Re: LV replacement cap irons......
Re: I should add..
Crude cap irons
Re: Stamping..
Re: It's worth a chuckle
Heavier Stanley cap-iron
Re: Heavier Stanley cap-iron
First one I saw...
That would've been my guess
Re: First one I saw...
Final smoothing isn't the problem
Re: Final smoothing isn't the problem
very interesting article *LINK*
Re: very interesting article
Re: Breaker, breaker, on mine, clear the pine
re: bevel-up
Re: re: bevel-up
Re: First one I saw... *PIC*
Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper *PIC*
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Quality is relative
Not really...
Re: growing pains..
Re: growing pains..
Re: growing pains..
Re: Latest Development
stay set
Re: stay set
The internet hasn't helped in some things..
Re: The internet hasn't helped in some things..
Re: LV replacement cap irons...... *LINK*
