Hand Tools
Re: Planes; knife geometry specifications *PIC*
Mark Hennebury
Warren the pursuit of perfection is a journey without end;
The closer you get, the more you focus and the imperfections are still seen, they just keep getting smaller and you keep magnifying, it is only when you step back you can see how far you have traveled.
Is a supersurfacer going to give you a perfect finish at all magnifications, no.
Keep in mind that technically the best surface is made by the first cut, as your blade edge degrades with each pass. If you were truly searching for perfection you would hone your blade for the final pass. But from a practical level a supersurfacer does an incredible job, at incredible rate, for a lot fo lineal feet between sharpenings.
Also i would caution you on making judgement of the surface from the video, as it is really hard to definitively say what the surface is like from the video. To be sure you would need to examine it in person, preferable under magnification. The surfaces have been studied and verified scientifically in Germany and Japan under scanning electron microscopes.
See images below.
What a supersufacer is, is an attempt at perfection; and at that it is the closest that i have seen.
They have put effort and research into understanding and improving the mechanics of cutting wood.
they have advanced and documented the specification of tool geometry.
They have researched and developed knife steel, grinding and sharpening.
A fine planed surface is a subtle but brilliantly beautiful thing to experience, but sadly something only a few appreciate or even notice.
They deserve a lot of respect for "going against the grain" When sanding is so much easier to sell.
Images from the Arco Baleno website
© Pictures SEM E.Bäucker kindly consented by the T.U. Dresden.
Pictures of super surfaced woods, taken by a scanning electron microscope (SEM)
Some woods that i dressed as sample, note the reflection on the walnut.
Messages In This Thread
Planes; knife geometry specifications *LINK*
Re: Strawmen
Re: Strawmen
Who are the teachers?
Re: Who are the teachers?
Re: All screwed up?
Re: All screwed up?
Skepticism *PIC*
Re: Skepticism
Re: Skepticism
Re: Skepticism
Re: Strawmen
Print from 1993 *LINK* *PIC*
Re: Print from 2010 *PIC*
Re: Print from 1905 *LINK* *PIC*
Re: Print from 1950 *LINK* *PIC*
Integral Chipbreakers in handplanes *PIC*
Re: Integral Chipbreakers in machines *PIC*
Re: Integral Chipbreakers in handplanes
Re: Print from 1917 *PIC*
Re: Print from 1905
Re: Print from 1905
Re: Print from 1993
Re: Print from 1993
Re: Print from 1993
Re: Print from 1993
Re: Print from 1993
Re: Print from 1993
Re: Print from 1993
Re: Print from 1993
Re: Print from 1993
Re: Print from 1993
Re: Print from 1993
Re: Print from 1993
Re: Print from 1993
Re: Print from 1993
Re: Print from 1993
Breadth of forum participation *NM* *LINK*
Re: Breadth of forum participation
Stanley...anyone care to comment? *PIC*
Occasionally, someone thinks they have...... *PIC*
I wish I had a wheel..
Re: Occasionally, someone thinks they have......
Beautiful workbench Roger! *NM*
Thanks Mark.....
Perfection exists to be pursued not caught. *NM*
Re: Stanley...anyone care to comment?
Re: Print from 1993
Re: Print from 1993
Thanks William. *NM*
Re: Strawmen
