Hand Tools
Crude cap irons
Re: I should add.. ()
Patrick Chase
There is such a thing as a cap iron that's so crude that it acts as a shaving trap.
Exhibit A in that regard is WoodRiver/Quangsheng. The milled LN-style caps on their planes have a very rough finish on the face with deep vertical (from tip->top) striations. The first time I encountered one I trued and cleaned the edge, honed a polished 50 deg "breaking face" at the base and tried to put it to work as I was trying to help a friend with his plane and in a hurry. It promptly started trapping every thin shaving I tried to take.
You would think that vertically oriented striations wouldn't be as much of a problem, but these were so deep that they acted as "shaving velcro".
Going back to the question of "how much tuning is enough" from Derek's post, my own experience is the following ordered list of priorities:
1. Flatten, undercut, and clean the leading edge of the cap iron. It doesn't have to be super sharp (see previous posts on that topic) but it needs to register well and not have any nicks/burrs/etc that might act to "hook" the shaving.
2. Create (if necessary) and polish the 45-50 deg "breaking face" immediately adjacent to the edge. This needs to be (very conservatively) ~0.5 mm high, as the shaving generally hits it within the first couple tenths of an mm. There is an interesting experiment you can do - paint the breaking face with something that rubs off easily like dry-erase marker, set the cap iron close, and go plane a bunch of wood. It's surprising to see where the shaving actually contacts it.
3. Polish the rest of the cap iron face above the breaking face.
4. Reshape the primary bevel to eliminate hard corners.
Warren has strongly advocated doing all 4. My experience is that the 80/20 rule kicks in at step 2 - once you get that far it will work for most practical purposes. The WoodRiver is the only cap iron I've used that actually needed to go to step (3) to work *at all*.
Messages In This Thread
LV replacement cap irons......
Re: LV replacement cap irons......
Re: I should add..
Crude cap irons
Re: Stamping..
Re: It's worth a chuckle
Heavier Stanley cap-iron
Re: Heavier Stanley cap-iron
First one I saw...
That would've been my guess
Re: First one I saw...
Final smoothing isn't the problem
Re: Final smoothing isn't the problem
very interesting article *LINK*
Re: very interesting article
Re: Breaker, breaker, on mine, clear the pine
re: bevel-up
Re: re: bevel-up
Re: First one I saw... *PIC*
Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper *PIC*
Re: Sandpaper
Re: Sandpaper
Re: Sandpaper
Quality is relative
Not really...
Re: growing pains..
Re: growing pains..
Re: growing pains..
Re: Latest Development
stay set
Re: stay set
The internet hasn't helped in some things..
Re: And it hasn't helped in others...
Re: The internet hasn't helped in some things..
Re: LV replacement cap irons...... *LINK*
