Hand Tools
david weaver
I don't know what your client group is like. My bench top is a bit bigger than you described, but not much. I don't love tearout because I do metal and woodwork on the same bench (and I know that's a mortal sin). I don't want to have to do more than card scrape the top quickly to remove any metal contamination. My bench top is ash. It was easier to plane wihthout tearout than it probably would've been with. I didn't pay any attention to grain direction when laminating it, and I'd expect not to. Ash is contrary enough that even with the cap set, it wasn't that pleasant to plane. I can't imagine planing it, even to prep for sanding, if one was to allow tearout. That wouldn't have been as much of a problem if I had made it out of soft maple or something less contrary. The entire bench build took about 30 or 35 hours. I didn't spend much time planing it, and it is not a work of art, but it is materially free of tearout.
We have an ash death problem here (the ash borer) so I bought the cheapest I could find, which was delivered and not picked. I guess I could be chastised for working junk material, but it seemed ideal for a bench.
But regarding the table top you describe. I'd probably plane it - not in your circumstances (where there's 25 more jobs behind it and you need to get out of bed the next day and go at it again), but in mine.
I have no idea how many people would pay for a hand planed surface, but I think Brian has found some. I'll bet it's below 2%, as you say. I agree with you, and it reminds me of a body man I heard talk about filling rust damage in cars for a used car dealership. You do the work you're paid to do. If you start trying to do an A level job on a C level price, you'll go out of business quickly.
Messages In This Thread
Redoing the test
Re: Redoing the test
If you're a beginner...
Re: And a quote....
Re: The other issue...
Contrariness
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Remarkable restraint
Re: Remarkable restraint
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
Maguire
Re: McGuire
The Virtue
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: The most likely
Re: The most likely
Re: The most likely
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Set-back distance and measurebation
swingley thread
Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Blackburn
Cap iron sharpening
Re: Cap iron sharpening
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Cap iron sharpness
Re: Cap iron sharpness
Re: Pictures
Re: Pictures
Re: Pictures
Cut depth, species, and wear
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Re: planing
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
