Hand Tools
Re: I recall
I knew *PIC* ()
David weaver
That you knew what you were talking about when you joined the discussion, Mark.
Messages In This Thread
Cap iron setback and shaving thickness
Redoing the test
Re: Redoing the test
If you're a beginner...
Re: And a quote....
Re: The other issue...
Contrariness
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Remarkable restraint
Re: Remarkable restraint
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
Maguire
Re: McGuire
The Virtue
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: The most likely
Re: The most likely
Re: The most likely
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Set-back distance and measurebation
swingley thread
Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Blackburn
Cap iron sharpening
Re: Cap iron sharpening
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Cap iron sharpness
Re: Cap iron sharpness
Re: Pictures
Re: Pictures
Re: Pictures
Cut depth, species, and wear
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Re: planing
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
