Hand Tools
david weaver
It sounds like efficient is doing more?
I've not had any real rust problems on the business end of a cap iron, and my humidity is about the same as yours, but for a different reason than just due to the local weather. My garage is mostly underground and moisture comes through the floor slowly. That's compounded by it being about 10-15 degrees cooler than outside, which drives the relative humidity up (I'm sure you know how that calculation works).
The magic point for humidity is something like 63% relative humidity. It's uncommon for my shop to be below that in the summer due to the RH outside and the temperature differential.
I don't have to deal with my shop getting to 100 degrees like you do, but the rust can be an issue - especially at the point of contact where the iron and cap meet on an unused plane (that's pretty easily prevented with wax for a plane that's going to see little use, though).
I've never used 3 in one in my shop for anything, but I haven't had any problems with rust on cap irons. I didn't think I had any filth on mine, but the pictures do appear to show some wood residue. Until it causes a problem, it's no problem. I've never used steel wool on the business end, either - that would be very undude.
I think you're solving a problem that doesn't exist, and that's supposed to be my specialty and not yours.
Messages In This Thread
Cap iron setback and shaving thickness
Redoing the test
Re: Redoing the test
If you're a beginner...
Re: And a quote....
Re: The other issue...
Contrariness
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Remarkable restraint
Re: Remarkable restraint
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
Maguire
Re: McGuire
The Virtue
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: The most likely
Re: The most likely
Re: The most likely
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Set-back distance and measurebation
swingley thread
Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Blackburn
Cap iron sharpening
Re: Cap iron sharpening
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Cap iron sharpness
Re: Cap iron sharpness
Re: Pictures
Re: Pictures
Re: Pictures
Cut depth, species, and wear
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Re: planing
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
