Hand Tools
Re: Worn Through
Re: Cap iron sharpening ()
david weaver
(I'm practicing using titles that are representative rather than making a long list of posts with a title that bears little resemblance to anything other than the first post.)
My wooden planes generally remove the first layer of crap with new lumber. Sometimes the lumber is dirty, but usually not so bad. Those are large shavings, and if the edge is bad enough, I just strike a line and cut it off. On the face, the jack plane takes off the junk. so far, I haven't noticed anything on it (the sole is very slick looking with some big scratches from various untoward things, like staples or accidentally running the plane across something, etc).
So, anything after that is working fairly clean wood.
However - point of the title - the very first #8 that I ever bought was sold to me by an unscrupulous seller. It had a diagonal groove down the center - to the left on the rear and to the right on the front - you know what I mean. The cap iron was split in two at the center. It must've been used to take the edge off of dirty wood, one after the other, and the seller neglected to mention that the cap was worn through in the center. Maybe it was stuck in some kind of fixture, I don't know.
So, if the wood is bad enough, I guess you can mess up the front of the cap (but that should be long gone before you get to your "fine" planes. Aside from that, if I have the cap set close and take a healthy swipe of filthy wood off (something I don't have that much of, but from time to time, you still get), I don't think much dirt contacts the cap iron - the underside of the dirty wood does.
Thanks, by the way, for the earnest participation in this discussion.
And, remember the picture of the wood with a bit of tearout that you rode me about in the article? You were certain that I must've seen it at some point, and that i allowed it as a "piece of wood that wasn't ready for finish". You're in the place to actually ask a question about that piece of wood. I'm still patting myself on the back for not making a big deal about it, because I tend to go all or none on most things, and on the human side of things, I actually recognized that folks were making an effort on their time and dime to edit an article that I put together.
Messages In This Thread
Cap iron setback and shaving thickness
Redoing the test
Re: Redoing the test
If you're a beginner...
Re: And a quote....
Re: The other issue...
Contrariness
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Remarkable restraint
Re: Remarkable restraint
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
Maguire
Re: McGuire
The Virtue
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: The most likely
Re: The most likely
Re: The most likely
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Set-back distance and measurebation
swingley thread
Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Blackburn
Cap iron sharpening
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Cap iron sharpness
Re: Cap iron sharpness
Re: Pictures
Re: Pictures
Re: Pictures
Cut depth, species, and wear
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Re: planing
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
