Hand Tools
Re: HAck saws - whatever floats your boat
Jigs for float-making? ()
I found making the edge float easy, but the ones where you file the whole face of the piece of metal are hard to make without rounding. I tried my usual trick of "always be hollowing" but it still came out mostly rounded. I always mean to finish the job by setting up on the mill, but I get by so motivation is lacking.
There are several levels of float need:
- There is the need to make good planes - floats not needed.
- There is the need to make planes as they were intended to be make - a few floats needed
- There is the need to make planes efficiently with clean surfaces all over.- Need a lot of floats.
- The above and make all kinds of planes - all of the floats are needed.
I have found you can get remarkably far with hack saw blades, consider you are on a desert island, and you need to make some great planes to build a boat, and all you have for floats is one very narrow edge float in both push and pull variation, and maybe the means to gang them.
