Hand Tools
Warren in Lancaster, PA
As David mentioned, a thick iron helps reduce chatter, which is vibration of an iron that is not well bedded. It shows up as regular ridges on the planed surface. A decade ago, people who were unfamiliar with double irons were suggesting that all that a cap iron did was to make a stiffer iron (emulate a thick iron).
What a double iron is good for is tear out, which is quite different from chatter. Tear out occurs when the plane goes over a region where the grain is going in a contrary direction. The fibers are lifted and broken off ahead of the cut reulting in a rough and torn surface. A well adjusted double iron will remedy this problem, leaving a very smooth surface.
Although some suggested that a thick iron would help with tear out also, this does not really happen. Instead, people using single iron planes have depended on other remedies such as high angle of attack, tight mouth, or extremely light shavings. The double iron does not have these restrictions and because the angle can be low, yields a better surface.
Messages In This Thread
Cap iron setback and shaving thickness
Redoing the test
Re: Redoing the test
If you're a beginner...
Re: And a quote....
Re: The other issue...
Contrariness
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Remarkable restraint
Re: Remarkable restraint
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
Maguire
Re: McGuire
The Virtue
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: The most likely
Re: The most likely
Re: The most likely
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Set-back distance and measurebation
swingley thread
Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Blackburn
Cap iron sharpening
Re: Cap iron sharpening
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Cap iron sharpness
Re: Cap iron sharpness
Re: Pictures
Re: Pictures
Re: Pictures
Cut depth, species, and wear
Tried this again today
Re: Tried this again today
planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Re: planing
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
