Hand Tools
steve voigt
Patrick, thanks for doing this. While I agree with an earlier comment that the tests done on forums are often not very enlightening, I think this is a good one. The variables are few, the situation is realistic, and you don't overreach, or compare apples to orange, or commit any of the multitude of other experimental sins that people fall into.
The interesting conclusion for me is the big increase in force. Thinking back to my experiments with cambered cap irons, that was probably the biggest deal breaker.
At the risk of stirring up trouble, I will point out that this doesn't prove that one can't set the cap iron below the sole with a cambered jack iron. The force of having a straight iron 1 mil below the surface is obviously greater than say having a heavily cambered iron 2 or maybe 3 mils below the surface at the deepest point. However, even if you haven't tested this scenario, I doubt the conclusion would change much.
Messages In This Thread
Redoing the test
Re: Redoing the test
If you're a beginner...
Re: And a quote....
Re: The other issue...
Contrariness
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Remarkable restraint
Re: Remarkable restraint
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
Maguire
Re: McGuire
The Virtue
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: The most likely
Re: The most likely
Re: The most likely
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Set-back distance and measurebation
swingley thread
Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Blackburn
Cap iron sharpening
Re: Cap iron sharpening
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Cap iron sharpness
Re: Cap iron sharpness
Re: Pictures
Re: Pictures
Re: Pictures
Cut depth, species, and wear
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Re: planing
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
