Hand Tools
david weaver
Ridging is pretty severe. Generally, if I think it's remotely painful to finish a cut, I'll back off on shaving thickness.
I think in your setup (keeping in mind that I've never measured anything, so I'm ballparking), I'd probably end around 4. Even at that, when you look at something like softwoods, you can see evidence that a cap was set close.
I'll bet Warren would spot that kind of thing in a second (the evidence of crushing), but I'm not sure many other people would. When I first started, I leaned a little on the too close side to try to ensure no tearout and I do recall Warren suggesting that it was on the less practical side of things. That sort of came from what I said above, that you can eliminate tearout really quickly. It's the rest of the subtle things that go with cap iron use (using it to your advantage to make planing pleasurable as well as efficient and sustainable - not to mention predictable and dead accurate) that take a little more time to nail down. All of the really significant advantages come out of that - and those were the things that I was lacking when I was using a long plane from the early 1800s to do my middle work - one with a single 50 degree iron. A beautiful plane, by the way, but it taught me what I wanted.
By the way, which maple are you talking about - western bigleaf maple?
Messages In This Thread
Redoing the test
Re: Redoing the test
If you're a beginner...
Re: And a quote....
Re: The other issue...
Contrariness
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Remarkable restraint
Re: Remarkable restraint
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
Maguire
Re: McGuire
The Virtue
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: The most likely
Re: The most likely
Re: The most likely
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Set-back distance and measurebation
swingley thread
Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Blackburn
Cap iron sharpening
Re: Cap iron sharpening
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Cap iron sharpness
Re: Cap iron sharpness
Re: Pictures
Re: Pictures
Re: Pictures
Cut depth, species, and wear
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Re: planing
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
